- Joined
- Apr 15, 2018
- Points
- 19
- Model of Z
- 1.9L Z3
About one year ago (and 5000 miles) I changed the master cylinder, slave cylinder and clutch lines. Basically everything clutch related after the line that goes from the reservoir through the firewall. I bleed the lines and remember it not feeling 100% but after leaving it a day it eventually settled and seemed to be working. Sometimes it's been a little tough to change into gears but I always just assumed that's because it's an old car.
I drove the car on the weekend and it was working fine. Today I turned on the car and can not change into gear. With the clutch in I'm unable to change into any gear. With a little bit of force it feels like the engine is starting to stall if I try to push it into gear with the clutch on the floor. I can change gears with the engine off though.
I don't understand what could have changed recently. I bleed the clutch line again this afternoon and no change. I removed the slave cylinder, applied 10psi force to the brake reservoir and depressed the shaft with the bleed nipple open. I then installed the slave cylinder into the transmission, although I had to loosen the bleed nipple to get the shaft to compress in. I then released the nipple and pumped the clutch, all with pressure on the brake reservoir. It didn't make a difference.
I don't see what else it could be, the brake system appears to hold pressure so I don't think there is a leak. Does anyone have any ideas what could cause this?
