Type of replacement waterpump
Discussion in 'Z3 Roadster & Coupé' started by pina4greg, Nov 1, 2014.
  1. pina4greg
    pina4greg Dedicated Member
    Australian Zeds
    Sep 23, 2014
    52
    57
    31
    Perth, Western Australia
    Model of Z:
    2000 z3 2.0 litre, 5 speed manual
    Just trying to get a sample of the types of water pump that have been replaced in the z3.
    i have found that there are the originals with plastic impellers, ones with composite impellers and then the metal ones.
    can you tell me your experiences regarding price and quality and improvement<
  2. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,320
    9,646
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    When I changed my I bought a metal impeller version from my local motor factors, but that decision was purely on cost at the time. If I could have afforded it I would have probably gone with a Stewart pump on reputation.
    As for quality, it's been in there several thousand miles and hasn't broken yet!
  3. Cooper
    Cooper Zorg Guru (IV)
    Supporter Australian Zeds
    Apr 17, 2014
    1,175
    763
    157
    Hobart Tasmania Australia
    Model of Z:
    3.0i 2001
    There are quite a few posts on this. The consencious seems to be the Stewart but if you cant get that then get one with a metal impeller. Please excuse spelling mistakes i am on the Tab!
    There are a lot of dif experiences with some people changing out their plastic impeller pumps with no damage whatsoever! Others have had failures and wish they had a Stewart, and usually get one!
    Hope that helps.
  4. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,442
    708
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Stewart's are good but expensive. I fitted a Meyle (metal impeller) - good quality and mid range price.
    • Agree Agree x 2
    • Like Like x 1
  5. tower
    tower Zorg Guru (I)
    British Zeds Scottish Zeds
    Sep 15, 2014
    286
    343
    89
    Gourock
    Model of Z:
    Z3 2.2 sport
    have just finished renovating the cooling system ,water pump was a Kohle Schmidt (metal impeller) oem replacement from c3bmw
  6. vintage42
    vintage42 Dedicated Member
    Dec 24, 2013
    227
    66
    39
    Most Z3s were given solid composite plastic impellers, probably a good compromise of cost and light weight and durability.
    Metal impellers can be either solid or sheet. The solid metal Stewart or Geba impeller is a replacement upgrade, does not come apart, but their weight can shorten the life of the pump bearing.
    Here's a video showing a Graf pump with an impeller made of sheet metal that is spot-welded:
    View: https://www.youtube.com/watch?v=eeFUhg8PmDk
    They can come apart.
    http://www.m3forum.net/m3forum/showthread.php?t=338159
  7. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,991
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    Seems to me that the unevenness would put undue stress on those few spot welds and uneven pressure on the bearings, from the waterpump in the video. Kind of scary that all that fragmented metal could get circulating in the engine. JIM
  8. vintage42
    Dec 24, 2013
    227
    66
    39
    At least it's in the cooling system, not the lubrication system.
    • Agree Agree x 1
