Donkeyoaty
- Joined
- May 19, 2016
- Points
- 39
Hi all,
I have just bought a 1999 2.8 Z3, but it is "skinned" in fibreglass and called a z300. I hope I don't offend any of you purists! It is in grey primer and I am going to get it professionaly sprayed in a Ferrari red.
The last Mot gave an advisory on the brake hoses. I have bought stainless steel ones. I have replaced them on my Triumph GT6 so I know the ropes!
That got me thinking of how to jack the car up. I know all the jacking points, but I would like to use a trolley jack to get the car up and use axle stands to support it all round on the jacking points. I know I don't need to jack the car up all round for this job, but I am really thinking of future jobs.
I have checked out a "bimmer" forum.
It seems you can use the trolley jack either on the differential (but not the cover plate) or the differential carrier.
The front seems more of a problem. One guy said he uses a trolley jack to jack up in the middle of the car on the side rail (I don't know if he meant the rail next to the jacking points) and then put the two axle stands on the jacking points on one side of the car and repeat the procedure on the other side of the car.
Another guy suggested running a two by four across the car between the two jacking points and using the trolley jack in the middle of the wood. I can't see how you could get the clearance to get the trolley under the wood ?
Photos would really help and any advice for this newbie....thanks.
