Went to have tracking checked today as steering wheel Is just off centred when driving. (Has been since I got it)
Turns out that the near side adjuster is seized and they could not move it even with heat.
Said only way was to have a new track rod assy. And quoted me £175.00 to do both sides. I was told that it may take a time to separate the unit to get it off.
I’ve been looking a prices and parts range from 25.00 for the pair to about 40.00 for one. (Different makes and quality?????)
The other thing I have found looking through the manual and online.....and please correct me if I have got this wrong, but to remove the track rod, you break a ball joint one end, and remove the gaiter and unscrew the other end, so you don’t actually have to do anything with the seized adjuster anyway????
If this is the case I’m sure it’s something I could do, and set it up initially by measuring the current distances then get the tracking done after.
Also where would be the best place to get a pair of track rods
I would be grateful for any help and advice
