Anyone out there using torque pro whilst driving? What layout are you using- what dials/graphs are good to have? Coolant temp is the reason Ive set it up but what others are useful? Dont need 0-60 times etc as I have a 1.9 lol
@NZ00Z3 mine stopped working , only worked the once, ordered another and the same 9will return that). Ive heard its hit and miss with them. Which adapter are you using?
I use a IKEGOL Super OBD WIFI dongle as I'm run my OBD2 app on an iPad.
The dongle gets hot when it's on for a long time.
Also note, that the power supply in the OBD2 connector is "Hot All the Time", so leaving the dongle plugged in when the car is not being used will drain the battery.
