Torque - Parts Terminology
Martin Sullivan
www.ZEDonist.com - ZED Parts
Cambridge, United Kingdom
3.0 Roadster
Hi all,
Thank you @Mazza for the great list of torque settings.
The main problem I’m having is finding the right description / terminology in the list.
Can someone help. I need to know:
Suspension struts - front - 2x bolts into hub / knuckle assembly. Is this “Steering Arm to Strut Housing”? 107Nm?
Outer track rod to hub / knuckle assembly. Is this “outer tie rod end to steering arm”? 45Nm
Control arm to hub / knuckle assembly. Is this “Control Arm Ball Joint to Steering Arm”? 62Nm
Having written this out, I think my question should be:
Is the front wheel hub / knuckle assembly referred to as the “Steering Arm” in the torque list provided by Mazza?
Thanks
Martin
Mazza
Bognor Regis
Hi Martin, all the info for the Torque list came from my Bentleys Z3 Service Manual. This is an American publication so you have to translate it in English 😂😂😂😂
Copied a couple of pictures for you, but if you need any more info please ask.
gookah
Shropshire
2.8 Z3
US to UK:
Driver's side = passenger side
Hood = headwear
Tire = become weary
Rotor = helicopter part
Trunk = elephant's nose
Gas tank = LPG storage
Fender = guitar
mind you, UK to US:
Bonnet = head wear
Boot = footwear
Wing = aeroplane part
Disc = music storage
Martin Sullivan
3.0 Roadster
US to UK
Hood = headwear
Tire = become weary
Fender = guitar
mind you, UK to US:
Passenger side = driver's side
Bonnet = head wear
Boot = footwear
Ha! Very good. We best avoid talking about Pants and Rubbers.:whistle:
And Fanny packs . . . . .
ZEDonist UK
3.0 Roadster
I thought I’d pull up my old post rather than create a new one.
The track rod end to knuckle and the control arm to knuckle have come loose despite being correctly torqued originally.
Everywhere else I used nylon nuts which have stayed tight but on these two areas I just used what was supplied with the new parts.
Does anyone know if these two areas would have had thread lock on originally?
im tempted to just swap them for nylon nuts
thanks
Martin
I would fit new nylocs but fit a spring washer first.
DrWong
3.0i
From memory when I refreshed my front shocks, the bolts holding the hub to the strut need threadlock. I replaced these bolts with new ones from BMW which had thread lock pre-applied to them.
I've also replaced both inner/outer tie rods but don't recall using threadlock for those bits and they've stayed tight.
On cars pretty much all nuts that are subject to vibration or movement with have some sort of locking mechanism on high stress it will most likely be nyloc or castellated nut and split pin on less stress bolts threadlock will more likely be used.
On a lot of the higher stress components the manuals will generally tell you to replace the nuts and bolts especially on stuff like rear hub nuts
Stephen.
  • Agree
Reactions: Lee
Delk
Hemsby Norfolk
Z3 2.8 real widebody
I love thread lock. Besides keeping things from coming loose it also helps seal the threads so you don't get any corrosion. And you can get it in a variety of strengths from just a little to you will never come loose ever.
ZEDonist UK
3.0 Roadster
Nope, more than 300 degrees! It was only finger tight and the same on both sides! Needless to say the handling was a little off 😬
I’ve never had anything come loose like this before especially after being torqued. Every other fixing was solid.
I’ve got some blue (medium strength) thread lock so having said I’d prefer not to use it I think I will.
