Hi peeps,
As my newly acquired Z3 is completely waterlogged under the carpets (surprise, surprise), I am trying to ascertain exactly HOW the top (big) windscreen/ roof seal is supposed to drain. I know the water has been running down the inside of the A pillars as the dashboard reinforcing bar is rusty in both corners, so presume the seal is the culprit.
The main channel in the seal has a small hole at each end which looks like it is supposed to drain down inside the a pillar seal, then another which links to the very end piece. This also has a small hole which looks like it does the same as the above. Any excess water then runs over and is guided by a rubber flap to drain down the outside of the A pillar/ windscreen.
Is this correct? Is the water supposed to drain inside the seal and discharge through the hole in the seal in the inside door threshold and run over the sills to ground?
Or are these holes a red herring and all the water is supposed to drain on the outside of the seal?
I have read about the plugs at the top corners and have checked mine. These are sealed but I will re-seal them at some point.
I know photos would help explain but the holes are so tiny and dark I can't get a decent picture.
I am not sure if I have any blocked internal channels in the seals, or if there are supposed to be any.
Thanks
Thanks
