Tool kit removal
Si Mcinerney
Harrogate
Perhaps a dumb question, however how do I remove the entire tool tray in order to replace it with a new one? Seems to be attached to the wire cable to the spare wheel.
Mazza
Bognor Regis
Drop the spare wheel down under the car.....
Item 3 passes through 9 and 17 and screws into the top of the threaded part on the carrier frame.
Usually stuck with rust.....flood it with WD40 and use heat. Its a 6 or 7mm open ended spanner to undo it.
Good idea to put some copper grease on it when assembling
Once that is off there are a couple of fixings on the toolkit tray.
