Wanted Tilt sensor
Jules56
Northumberland
2.2litre
Hi, can anyone tell me where I can get a replacement tilt sensor + cable/fittings? Car alarm went off after heavy vehicle got too close & couldn’t deactivate the alarm with key, opening doors, starting engine,etc! After looking online, saw YouTube post from a mechanic suggesting looking for signs of leaks around tilt sensor in left well of boot - sure enough, the poor sensor was submerged in rain water & falling apart with corrosion! Local garage suggested eBay, but I’ve typed in the code from current sensor & have drawn a blank. Does it have to be replaced with the same coded part, or are these items the same for different BMW models? Thanks, Jules
Eddie Zedder
Megawatt Valley, Notts.
Z3 2.0
You will also need an aerial grommet as that will be the likely source of the water coming in. Part no -
65218411562
Jules56
Northumberland
2.2litre
Amazing! Thank you. Most code numbers match mine, though not all - does it have to be an exact match? Sorry, I’ve no idea!
Jules56
Northumberland
2.2litre
Okay, thanks very much. Can I buy this from you & what’s your preferred payment method? Oh, 😂 and how much is it, including postage? Thanks, Jules
