throttle problem?
Discussion in 'Z3 Roadster & Coupé' started by don schultz, Oct 18, 2014.
  1. don schultz
    don schultz Newbie
    Oct 18, 2014
    4
    4
    3
    i just finished replacing the boots from the MAF to throttle body on my 2000 2.5 Z3 roadster. i knocked the throttle cable off in the process. after i got it put back on, the eml light and DSC lights came on and of course the vehicle went into limp mode with codes 1580 and 1622. isn't there a clip or something to hold the throttle cable to the pully? what did i do wrong?? help? thanks[​IMG]
  2. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,248
    9,469
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Hi Don,
    I'm not sure what could be wrong but if it helps.
    Error code 1622 relates to MAP Cooling Control Circuit Electrical
    Error code 1580 relates to Throttle Valve Mechanically Stuck
    • Like Like x 1
  3. don schultz
    don schultz Newbie
    Oct 18, 2014
    4
    4
    3
    thank you, i got those, but not sure what i did installing the boot and reinstalling the cable to cause those
    • Like Like x 1
  4. t-tony
    t-tony Zorg Expert (I)
    32,657
    15,351
    220
    Model of Z:
    Z4 3.0 Auto
    It might be worth removing the boot so that you can see the throttle flap, then have someone depress the throttle pedal to the floor to ensure the flap is opening fully? Error code 1580 might mean that not opening fully = stuck?
    Just a thought and easy to check.
    • Like Like x 1
  5. zedonist
    zedonist Guest
    the errors will come from the throttle position sensor, as it says mechanical malfunction, I would remove everything and re-attach it may be that the throttle cable is too tight and the throttle is open when should be closed, for example the cable nipple could be sitting proud and forward instead of in its recess.
    • Like Like x 1
  6. don schultz
    don schultz Newbie
    Oct 18, 2014
    4
    4
    3
    think that may indeed be the problem. i should have suspected, the cable appears to be patched/spliced and RTVed in multiple spots just as the air boot was. just got the car last week and have been busy trying to find all the stuff that has been neglected and rednecked. these forums are a national treasure of information better than any repair manual. thanks alot guys, now just have to pay through the nose for a dealer cable i guess/can't find it anywhere else. later
    • Like Like x 3
  7. don schultz
    don schultz Newbie
    Oct 18, 2014
    4
    4
    3
    took off the throttle body today and found the throttle plate doesn't seem to return properly, hence the mechanically stuck code. tried to clean, but the electronic portion still returns slow and doesn't want to fully close. bit the bullet and bought a new one. my bmw/tis says after installation i must go into the system and reset the throttle parameters. anyone done this? i have a edias/usb cable and software but have never used it. also found the mechanical throttle cable from the pedal to the throttle body is stretched and patched with electrical tape so have a new one of those coming as well. any help or advise offered would be appreciated once again
