Hi again. I'm still chasing running problems on my 1999 2.0 and had the OBD scanner on the car checking throttle position %. With the engine running unless you take the throttle well up you just get 0% all the time. Interestingly if you switch the engine off and operate the throttle up and down quickly the throttle position is shown (probably correctly) until the ECU shuts down. This to me suggests that the position sensors are working and reporting the position correctly but why doesn't the position show with the engine running, is this an ECU fault or is the engine running in limp/get you home mode and therefore the throttle position is not being read or used by the ECU and therefore not shown as other than 0% to the OBD socket? The symptom that has me chasing faults here is throttle hang when you take your foot off the pedal, return to tickover is slow, tickover is good and smooth. It's cable operated and is adjusted and working okay. No air leaks and oddly no fault codes are present.
