K Mazzei
- Joined
- Nov 13, 2021
- Points
- 3
This is on a 2000 Z3 2.8, When I replace the throttle housing MS42.1 the instructions at the end of the procedure in the BMW service manual read "Connect BMW test equipment or equivalent. Check for fault codes and clear and reset ECM memory. Reset throttle plate adaption values following on -screen directions."
My questions are
1. I have the ability to erase the codes with my generic code reader. I presume that is fine.
2. Can I reset the ECM memory by disconnecting the battery?
3. How important is it to reset the throttle plate adaption values? Is there another method to do this without access to the BMW tool?
Thanks for your time
My questions are
