jaguartvr
- Joined
- Jan 9, 2017
- Points
- 95
Have a late 2002 2.2.
Undergoing a body chop so there has been plenty pf dust flying around. I went to drive it off the ramp and it started fine but would only run at tick over. I have had this before with a 2000 2.8 which turned out to be a sticky throttle flap that just needed a tap to loosen it.
I have tapped this one and it moves but does not move when you press the throttle and I was surprised that this one doesn't have a throttle cable. I did have an E46 which had the wireless throttle which had a similar problem and it was the throttle pedal itself which was a common problem but the throttle pedal on the Z3 seems to be a traditional pedal.
Don't think a scanner will work as most of the wiring and intake assembly has been removed. The throttle body itself is in a pig of a position to remove so I thought I would ask before removing it and replacing it with a 2nd hand unit.
Odd that the car has been running fine and has been stored indoors on a ramp for a month should just develop this problem.
Anyone have any bright ideas?
