geeveejay
I have read so much on these codes my head is spinning. Have the 171 174 codes appearing on a regular basis and cant find the problem. Car is a 2002 2.2 with M54
So far I have replaced the lower boot ( that was split) gave a 303 code first, but thats never come back
Checked the manifold blanks at rear
Replaced Rocker cover gasket ( slight leak )
Replaced whole CCV system
Replaced DISA seal and upgraded to alloy flap
Small hose from F connector
Cleaned MAF with proper cleaner
o rings dipstick tube and dipstick
Can anyone see something obvious I am missing. Attached is a record of faults ( couldn't attach spreadsheet so its over 2 pages in PDF sorry )
Dont like to be beaten but dont want to keep throwing money at it randomly, car drives fine with no issues otherwise
Garage suggests it might be O2 sensors but they show Ok on my cheap scanner and surely 171 and 174 suggests both banks have an issue at the same time which is why I have been chasing vacuum leaks.
One thing I have noticed is a hiss of air a couple of seconds after shut down, cant figure what would make that noise, Next step is to take for smoke test but I am missing something obvious first
