The Z3 fuel filler lake
Davil
Australian Zeds
Sydney
Does anyone else experience a small lake beneath the fuel filler cap when washing the car? Doesn’t seem to be any sort of drain hole.
I’ve re-purposed a fuzzy pink sponge thing just for this job. Works a treat.
abh29
North Wales
Z3 2.2 Sports
Ours was very caked up to extent we could find it , but was easy to feed a length of Strimmer Cord up the drain tube from the bottom. Now make habit of checking when washing the car.
Davil
Australian Zeds
Sydney
Thanks! I’ll investigate next wash. Much appreciated Ian & abh.
Davil
Australian Zeds
Sydney
Brilliant. Thanks!
Clean the muck away find the hole inside of a pen Strimmer wire ( if thick enough) or similar to clear then pour some water to make sure clear and draining.
Stephen.
Mazza
Bognor Regis
If you ever take it out to clean, make sure you unclip the bottom end of the drain tube from the fuel tank.
I didn’t, and I ended up breaking it off where it joins the fuel cap gaiter.
Luckily I managed to fix it with gorilla glue.
  • Like
Reactions: Rha
