The Z Shed (Midlands).
And not a Z in sight, again. Recently it's been VW Crafter conversion keeping me and Gary busy,
today the lift had a different use.
Back to normal today after a good clean up.
Then it was onto my homework the boss left yesterday.
His extension lead had packed up. Usual culprit.
Then sharpen his chisels on the wet stone.
I did sneak a couple of mine in there too. Tomorrow they'll get finished on my oil stone.
Toby
N.E Lincs
Nice to see you keeping busy, Tony - wouldnt want you getting bored and the grey cells not used :cool:
I finished the chisels this morning on the oil stone,
and then told Gary they're ready when he needs them.
Then I thought I should wash the sawdust off the Z and the filth off the 4.
I ordered some 100 grit discs for my sander a couple of days ago and they were delivered this afternoon.
Spot the problem.
Toby
N.E Lincs
Wrong currency, they sent Pounds instead of Dollars ;) :cool:
Anyways, after putting all the wood butchering kit away our Abz says, "Can you make a bird table for the nursing home?" quite a few have dementia and she says it would help them, watching the birds. So,
And taken inside for the night to allow the glue to work.
Tomorrow is nesting box day.
Toby
N.E Lincs
Nice bit fo work there Tony, keeping your hand in too :cool:
Homework all done. Nest box made and collected along with feeding table.
Abz and Reid called late on and I put her A3 Cab.on the lift to fix the rear under tray which was hanging down a tad.
ExMX5owner
Moderator
Staff member
Australian Zeds
Queensland, Australia
I see a bit you missed Tony...:whistle:
It's recommended not to fit a perch as it encourages larger birds to stop and stick their beaks in.
Also make small hole as Tits will enlarge if they want/need to. Drilled at 25mm.
ExMX5owner
Moderator
Staff member
Australian Zeds
Ah I see.. :thumbsup:
The book cases that Gary and I made a few days ago have now been installed, and, in my opinion look pretty good.
Tony..
