yellowjacket
- Joined
- Oct 28, 2018
- Points
- 22
Hello all - My Z3 came with about 180k miles and a roof leak which left the (right hand) passenger seat filled with water after a rain. I GummiPhledged and more importantly sealed the top of the A-pillars (wit Sugru--great stuff) and the seat no longer fills up, but water is still getting in. Using the tried-and-true paper towel test, I find the water is coming in on the right hand side between the seat and the door, toward the back of the seat. In other words, it is either entering about midway on the window or traveling down from the A-pillar area and dropping there. (see exhibit 1). While the water accumulates behind the right hand seat, it doesn't seem to be entering anywhere else.
I wonder about two things: One, the window on the door rides high above the frame piece (see exhibit 2), unlike the (nonleaking) left hand door. Could this be allowing a gap, or disrupting the usual drainage? Should troubleshooting include lowering the window position?
I've syringe-checked the drain in the A-pillar and was rewarded with a puddle, but wonder whether a more thorough drain cleaning would help, as well.
Thanks in advance for your thoughts on this, folks.
