Just enable our cousins over the other side of the pond to communicate correctly.. I thought this might help..
British term American term
accumulator battery
actuator switch or servo
Artic articulated lorry = "tractor-trailer"
baulk ring synchro ring
bonnet hood
boot trunk
bulkhead firewall
choke tube venturi
core plug freeze plug
crocodile clip alligator clip
crosshead Phillips
crown wheel ring gear
cubby box glove box or glove compartment
damper shock absorber
drive shaft half shaft or axle shaft
drop-head coupe convertible version of 2 door coupe
dumpy screwdriver short screwdriver
dynamo generator
earth ground
estate station wagon
fascia dashboard
fixed-head coupe 2 door coupe
frogeye bugeye
Gallon (Imperial) 5 US Quarts
gearbox transmission
gudgeon pin wrist pin
hood convertible top
jointing compound gasket sealant
lorry truck
mole wrench Vice grips
monocoque unibody
MOT DOT
Ministry of Transport Department of Transportation
nave plate hubcap
nose front of car
paraffin kerosene
pinking knocking or pinging
prop shaft drive shaft
petrol gasoline
prise pry
proud above or raised
quarterlight vent window
rev counter tachometer
ring gear flywheel gear, or starter gear
roadster car that only comes in a convertible style
roundabout rotary, traffic circle
RoStyle type of steel wheel (as opposed to wire)
saloon 2 or 4 door sedan
scuttle cowl
side curtains removable side windows
silencer muffler
sill rocker panel
Shooting Brake station wagon
spanner wrench
split pin cotter pin
spring washer lock washer
squab part of seat
suction advance vacuum advance
sump oil pan
thrust bearing throwout bearing
tickover idle
top gear high gear
torch flashlight
trunnion sliding or rotating joint (suspension)
Tyre tire
wheel nut lug nut
whitworth Brtish thread measuring standard
windscreen windshield
wing fender
accumulator battery
bonnet hood
boot trunk
bulkhead firewall
choke tube venturi
crosshead Phillips
dynamo generator
earth ground
fascia dashboard
frogeye bugeye
lorry truck
monocoque unibody
MOT DOT
nave plate hubcap
nose front of car
paraffin kerosene
petrol gasoline
prise pry
scuttle cowl
silencer muffler
sill rocker panel
spanner wrench
squab part of seat
sump oil pan
tickover idle
top gear high gear
torch flashlight
Tyre tire
wheel nut lug nut
wing fender
