The Gearbox is out!
So i have never removed a gearbox before which made me all the more interested to have a go.
If i'm honest the job is not really that hard you do need some specialist tooling but it's not expensive. Also the minimum of two people. I managed to get @GazHyde roped into helping.
I didnt really get time to take lots of photos but i will quickly explain what we did.
1) Get the car up on axle stands wheels can stay on.
2) Remove exhaust system from manifold back
3) Remove heat trays covering prop shafts
4) Disconnect guibo joint and prop shafts at diff end (easier with these out the way)
5) Remove clutch cylinder hook out the way also the gear linkages and any ancillaries
6) Start undoing the bell housing bolts (Inverted Torx fitting 11mm,12mm,14mm)
7) Once all the bolts are remove pull back the starter motor and wiggle gearbox free.
Enjoy
billz
Langley Mill
Good job Lee. I remember when i used to do all my own car jobs and removing a Capri 2.0 gearbox on my own on Axle stands to change the clutch. Now i would not even contemplate doing it.
It was an interesting procedure, and I should have taken more photos (I need to get myself a decent hand held camera to take pictures because I know my phones gonna get broken at some stage).
One step Lee didn't mention is making sure the exhaust has had plenty of time to cool down. :whistle: It's also important to make sure that you have the correct star shaped sockets and many different sized socket wrenches, and bars for extending the length of the wrenches.
Halfords sell the star sockets but annoying without an 11mm in the kit. So rather than buying a £10 set of 6 sockets, we left with an £80 full socket set which did include and 11mm.
So yet again further proof there is little that can't be maintained on the Z3 with a bit of effort and knowledge :joyful:
They'll be TORX sockets then;)
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
Thanks, I bought a Schnitzer complete shifter and apparently need to drop the trans to install it. This will help for sure even without the pics. JIM.
  • Like
Reactions: Lee
Some pictures of this evenings entertainment...
The offending beastie...
Inside the beastie...
Springs. Lee will have to explain what these do. He did tell me when he was changing them, but I've gone and forgot. Something to do with gear selection!
Underneath...
Gearbox ready to be lifted up...
Really not much room to swing a gearbox, let alone move it in to position...
Resting on Lee's chest...
Bench pressed in to place... A good upper body work out means Lee wont have to go to the Gym this week...
One of the bolts needed a few extensions and a knuckle added to the ratchet
Bazza
Verwood Dorset
when we do the oil change Lee we will have to get the car up a lot higher than that my belly would not fit under that car=))
I'm surprised we didn't do a full write up on changing the shift pins @GazHyde
Yeah, would have been sensible. I thought I took some pictures, but clearly not...
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I bet that if everyone did their own car maintenance and repairs over the next millennium the human male species will evolve to have an extra elbow in their fore arm and extra joints in their fingers =))
Redline
Nuneaton
E89 20i msport
Lee - You explained what you did but not why you needed to do it. Was there something amiss with the gear change?
Did you do the clutch and release bearing too?
For the cost I thought it was always worth doing when you've gone to the effort of taking the gearbox out.
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Would have been handy, my gearlever has started to stick to the right when cold.
This is exactly the problem my dad was having. A little birdy in the BMW garage told me its the shift pins that wear in the gearbox. In all the parts were around £50 for new pins and springs with caps. Fresh fluid and checked the clutch and all was well. Took a good day to get the job done.
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
Strange is that pins look good...
The new one look different as the old ones?
Brian H
Killin
If you get a moment will you look out the part number pls :)
