I bought a set of these https://www.ebay.co.uk/itm/323121666736 apparently they should fit without having to any penny washers on the front struts. Not got that far on my rebuild yet though.
Only use a brake line spanners on the fittings. Normal spanners have a tenancy to round the hex of the fitting.
When you get to the rear lines that go from the car to the sub-frame. Stop and look at how much of the nut hex is exposed for the spanner to grip. Then look at your spanner, there will be a curved lead-in on the spanner. I had to grid the lead-in off the spanner so that it got a good grip on the brake line nut.
