Suspension?
Dazbag66
Wanted advice my z3 1997 1.9 the ride height seems wrong the back is alot lower than the front checked springs all look ok ? Shocks look ok any ideas how get it at level by higher rear or lower front cheers?
Duncodin
Pontrhydyrun
Z3 M44
I'd say front it ok. Back is too low. Springs broken?
If you can get down at the back of the car and take a photo of the spring and surrounding area?
petecossie
Teesside
Z3 M Coupe
It could be that the front springs have been replaced at sometime in the past. The springs had to be replaced on my M Coupe a few years ago as N/S front spring snapped (only discovered at MOT) the new OEM springs meant the front does ride a fraction higher. They should be replaced in pairs.
As mentioned above thicker pads under rear springs might level it up for you.
Agreed but as Gaz pointed out the rear beam bushes need to be checked to see if the beam is sitting on the bottom plates too. Most likely a combination of problems if the car is all original.
