Having researched the various options for some time, the time has now come to "bite the bullet" as I have a broken rear spring and leaking front damper. These are thought to be original; the car has just turned 24 and at 100K miles, so they have lasted well.
Think my decision is to replace with Eibach pro springs and Bilstein dampers (B12 pro kit). Best price I can find is £709.77 (inc VAT) from Eibach shop. Will seek a supply and fit price tomorrow, guessing a couple of hours labour and tracking. Is it worth replacing spring mounts as a matter of course; the car had new ones fitted about 7 years ago?
Also have "slight play in the nearside lower ball joint" and a "split in the offside front lower arm rear bush". Guess its worth having this sorted at the same time.
Grateful for any thoughts/sanity checks on this.
Think the car should take the 25/30 mm drop OK?
Cheers,
Ian
Cheers,
Ian
