When I was at Cadwell Park on three occasions I got a sudden and unexplained stutter from the engine. By that what I mean the engine did a full stop and the started again all on it's own when I was at speed in high revs. After Cadwell I noticed the same thing about three times and also at traffic lights on two occasions the engine just stopped while I was in neutral writing for the lights to change. I called in my friendly auto electrician and he found that there were two errors one was the crankshaft sensor imtermittent and the other was that the vanos was physically jammed. He said that he would be surprised at the latter and said change the crankcase sensor and see if it cleared both. The parts from BMW were £89 for the sensor £37 from GSF but for both I had to buy an adaptor wiring loom from BMW which was about £16. Apparently on the earlier 2.8 there was a better way to wire up the system with the vanos so when I changed the crankcase sensor with the new wiring loom the problems went away. I have now done over 2000 miles without a single blip
Edit February 2013
I have now done a number of trackdays and many miles and the problem has not resurfaced also the Electronics have shown no errors since so that was a definite fix.
Sent from my iPad using Tapatalk
Edit February 2013
