Been looking into resolving the subwoofer issue i had in the zed.
I have the HK system and when turned up the sub just tends to quack rather than give bass.
Having removed the top cubby hole cover it revealed the enclosure.
Four screws to remove and the whole unit slides out and one multi plug to undo.
It would appear that two different enclosures are availible for the zed one like mine with 2 5.25" speakers fitted and the other which i believe is a single 6"
6 screws to undo and the enclosure comes apart showing the two speakers. These are fitted kind off back to back and i presume wired out of phase so they move in the same direction.
The speakers i brought where a componant set so have just used the 5.25" speaker with out any crossover as the amps feeding the correct frequencies.
A striaght forward swap out all screws and fixings identical.
Refitting was just the reverse of the dismantling.
Happy with the sound has given a better mid bass sound, Its an improvement for sure and an easy job for anyone with the same issues.
