Wanted Styling 32 from E39
Gundun
Belgian Zeds
West Flanders
2.2i Sport Line Individual
Hello,
I am in a quest for a styling 32 17 inches from a E39 staggered, so that being a 9J ET26, I will also buy the two if needed.
If you've heard about some or seen it onto some craigslists, just let me know, thanks
cheers,S
Dino D
Kent
2.8 Manual
There were quite a few e39 sets on eBay here for £350ish (8j front + 9j rears) but now just one set available...
I noticed quite a few in Germany Ebay which will be a better bet for you to ship. Also try that breaker in Germany - Schneidmann (they sell new spares too).
Gundun
Belgian Zeds
West Flanders
Staggered set on gum tree need a refurb but cheap
Et41 front et20 rear @Gundun what your after ?
Thanks @Antm72. The ET20 has the 8J, and it's narrower than the ET41 8,5J I have on now. The plan is to keep the ones from the staggered set I currently have at the front and swap the rear with the ET26 9J, that are wider and larger on the track
Antm72
South Yorkshire
Not quite as wide but deeper dish by nearly 15mm
Rim is only about 10mm narrower.
Look wise the rim your looking for will add 6mm to the dish the rest will be inside.
Good luck with the search the rim you want has to be out there.:thumbsup:
Antm72
South Yorkshire
Only set I can find anywhere and not cheap but then appear not to be commonly available :/
