I don't know how to link it, but I just used search to find my write up 'Stuck Bonnet '.
I hope this helps, I cut and pasted this:- (god I'm useless with these computers!!)
Had an afternoon of fun today.
SWMBO decided to check the oil, and couldn't open the bonnet, the cable was not operating anything.
I managed to pull the o/s kidney grille off without any damage (I don't think it had been fitted correctly), anyway, I could just see the cable that goes between the two locks, I jammed my hand inside and managed to give it a pull with just my fingertip, pop went the n/s lock and nothing else!
I did a search on various forums, ideas varied from smashing the o/s headlight out!!! to air sawing bits off!!!
One suggestion concurred with my next plan of attack.
I raised the front of the car up and removed the undertray, on my back, once my eyes adjusted to the gloom and the little light of my phone, you can just see half of the o/s lock, the half that carries the cable to the other side. The arm and cable are in a little recess where I managed to get a long flat screwdriver into it, by twisting, the arm can be moved towards the o/s and popped the o/s lock. PHEW.
It turned out that the inner cable is intact and seems to be stainless steel, but the outer cable is rotten at the end and no longer attached to the lock.
I cut the cable a couple of feet back and removed the outer cable, tied a loop in it so it just fits above the o/s headlight.
The bonnet can now be opened by pulling the loop of wire (using a bit of rag, it's a bit cutty).
New parts are on order, judging the condition of the cables, if I'd known, I would have changed them earlier and saved a lot of worry and hassle.
