Strippers Ahoy!!!
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
I am preparing my Zed for a partial resray and thought that I would like to share a few pictures of my efforts today :-ss
The reason it needs a respray, is that the front end has been peppered with stones over the years and as it is a dark colour it presently shows every chip, in fact I have never seen so many stone chips on a car before, I came to the conclusion that the previous owner lived next door to a gritter 8-|
The bonnet, the nose cone and the off side wheel arch panel are due to be sprayed this week. :-bd
We will post further pictures as work progresses :)
DangerousDave
You are not alone ;) .
Two sills, two indicator panels, front bumper, rear wing and boot returned from the sprayers yesterday. Will start putting the Meccano kit back together during the week.
Snoops
Red Rose Country
Be good to see side by side shots of the before and after body parts.
Had similar done last year myself, even more pleasure waxing him now.
How are your mirror bases?? I could see a very tiny bit of bubbling on one (hardly noticeable) but I got it done at the same time.
z3cade
Peterborough
Wow
:-o
You've done well today Mike!! Sorry I couldnt be there to lend a hand.
Well done!! :ymapplause:
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Hi Dave. Please list what you have broken so far, :D my list consists of 1 x horn, it just fell apart and 2 x washer nozzles, the plastic was very, very brittle. The process also revealed that the front brake discs need replacing.
Are you posting any pics of your project?
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Hi Snoops, We had the passenger side mirror base done last year, the drivers side will have to be in with a future project another time $-)
As they are going to the body shop tomorrow morning early, I will go down now, just for you, Snoops, to try and capture a picture of the stone chips, problem is they are so numerous, but minute, I don't think that I will be able to focus in enough to do them justice #:-s
z3cade
Peterborough
Did the front bumper come off ok mike?
DangerousDave
EnthuZiaZT said:
... what you have broken so far, ...
See above for pic.
I have broken some of the white clips that hold on the sill covers, but I have found other parts that are broken / needing replacement. Such as the fuel filler cup (not the cap, but the rubber thing that diverts spilled fuel down the overflow) and some plastic panels. I replaced the cup (£20) and "glued" the broken plastic with a soldering iron.
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Yes Liam, only two torque bolts hold the front bumper on, once they and the undertray have been removed the bumper just slides off. Wiring is a doddle to disconnect. :-bd
The wheel arch liners, as you said, are more complicated, but once you've done one, the other is easier. :)
HornelZ3M
Raglan. South Wales
Z3M Roadster
Oh my god mike, hope its finished by Silverstone or you will be the best car for cold feed. ;) You gotta nerve doing all that :-ss :-ss
si-forks
worcester
I'am sooo jealous of your garage !!! i really need to get my bonnet done , looking good
Si-forks on tapatalk
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
After several years of restoring cars in all weathers, Si-forks ~x( it is good not to have to worry about whether it is going to rain on the very day you've planned a project :D
I also built an RSJ in the garage, so that I have been able to fit a chain hoist on rollers to lift an engine out, which came in handy a couple of years ago, replacing a normally aspirated diesel engine in a Landrover 90, with a 200 tdi Discovery engine. :ymsigh:
Fortunately, we have a body shop two doors down and he gave me a good price to include the bonnet :-bd
B
badman gee
Guest
Fortunately, we have a body shop two doors down and he gave me a good price to include the bonnet :-bd[/quote]
mike, will be interested to see the results.
i have a couple of bits need doing on the rover!
SilverZed
Sunderland
Tip top work! I'll be doing something similar if I decide to keep my 2.2 long term (I am considering trading up to a 2.8 or 3.0 - the 6 pot sounds the dogs but I wouldn't mind a bit more bottom end torque). Bolt on panels are great aren't they? I remember having to grind welded wings off cars when I was a boy! That was back in the days when I used to have an oxy-acetylene kit at the back of the garage!
SilverZed
Sunderland
Does the 2.0 model have a different fan arrangement? My 2.2 does not have that plastic fan cowling behind the grille - you just see the rad and the fan is on the other side.
Cheers.
Deano.
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Do you still keep the oxy-acelylene in the back of the car ready for the wheel clampers, SilverZed :ymdevil:
EnthuZiaZT
Heacham Norfolk
Z4 28i Msport
Cheers.
Deano.
My 2litre has two fans, a viscous coupled one to cool the engine and the electric one that you can see in the pictures is for the air conditioning. :-bd
SilverZed
Sunderland
Ah I see. Thanks. I didn't realise this being a non ac pauper! Do you use air con with the roof down? It could combat global warming! :))
