strange temp gauge?
Discussion in 'Z3 Roadster & Coupé' started by robertjones, Sep 17, 2014.
  1. robertjones
    robertjones Regular Member
    Sep 13, 2014
    48
    10
    18
    Noticed on my z, the temp gauge moves up to the halfway mark after maybe, half a mile of setting off from home , even though the engine hasnt warmed up, it then stays there however fari travel, uses no water and fan kicks in o.k. , doesnt seem to overheat Is this normal ? As my last z would run for quite a while until the engine warmed up before moving to normal, engine is 1.9i
  2. Brian H
    Brian H Zorg Guru (V)
    British Zeds Scottish Zeds
    3,457
    2,500
    195
    Killin
    Model of Z:
    E36/7 3.0i - E85 Z4///M
    Robert,
    If it aint broke don't fix it :), the temp gauge is a buffered gauge so when the needle sits in the middle it will cover a range of 20 or so degrees.
    Brian
    • Agree Agree x 2
  3. robertjones
    Sep 13, 2014
    48
    10
    18
    Agree with u but just think its unusual and wondered if anyone elses z was the same , as I have never had a gauge that worked llke that before as soon as I leave the house the temp starts showing a reading
  4. GazHyde
    GazHyde The Gaz Monkey
    Dec 2, 2011
    15,135
    9,211
    Newbury, Berkshire
    Model of Z:
    BMW Z4 3.0Si Sport
    Doesn't take very long to get to the middle on my 2.2.
    • Agree Agree x 1
  5. Brian4
    Brian4 Zorg Guru (IV)
    British Zeds East Anglian Crew
    Dec 23, 2011
    2,505
    1,996
    173
    Hinckley/Burbage
    Model of Z:
    Z3 3.0i Auto
    Same in ours gauge quickly to mid point and heater blows warm air about 5 mins later.
    • Agree Agree x 1
  6. robertjones
    Sep 13, 2014
    48
    10
    18
    Sounds as if its the norm. For some of these cars then, unless yours is unusual as well!
  7. oldcarman
    oldcarman Zorg Guru (V)
    Supporter Canadian Zeds The M44 Massive
    Feb 11, 2014
    9,986
    3,617
    177
    Pine Falls Manitoba can.
    Model of Z:
    Anyone had intermittent temp gauge problem? Works normally or not at all? JIM
  8. hard top
    hard top Zorg Expert (I)
    Dutch Zeds The M44 Massive
    20,757
    6,044
    213
    Netherlands
    Problems in the bedroom department Jim?.......;)
    • Funny Funny x 1
  9. t-tony
    t-tony Zorg Expert (I)
    Supporter British Zeds
    30,630
    14,419
    220
    Model of Z:
    Z4 3.0 Auto
    Mine does the same as Gaz and Brian's cars. I've had it over 4years now and it's never been any different.
    As Brian H said and I agree.
  10. Brian4
    Dec 23, 2011
    2,505
    1,996
    173
    Hinckley/Burbage
    Model of Z:
    Z3 3.0i Auto
    Just looking on the wiring diagram for the Z3 and the coolant temp sensor for the gauge is at the rear of the cylinder head under the inlet manifold so it will get to see any heat pretty quickly perhaps that is why is rises fast initially. It also feeds through the DME control unit and this gives the analogue output to the temp gauge. Electronic wizardry so the likes of most of us cannot understand.
    Gone are the days when one sensor is connected directly to the display for that item.
    The speedo isn't driven by the gearbox but by the wheel speed sensors used by the ABS and AST or DSC and a sensor in the rear axle.
  11. zedonist
    zedonist Guest
    I've found mine does not work when i switch the engine off, it works again when i switch it on, must be an intermittent design fault.:woot:
    • Funny Funny x 3
  12. t-tony
    30,630
    14,419
    220
    Model of Z:
    Z4 3.0 Auto
    Speedo cables are long gone Brian, except if the elastic has gone in them.:ymdevil:=))=))
    • Funny Funny x 1
  13. robertjones
    Sep 13, 2014
    48
    10
    18
    Blimey, no wonder it goes up so quickly!
  14. Brian4
    Dec 23, 2011
    2,505
    1,996
    173
    Hinckley/Burbage
    Model of Z:
    Z3 3.0i Auto
    Point I was trying to make Tony.
  15. zedonist
    zedonist Guest
    Just a clarification the speedo is controlled by a fan disc and sensor in the differential only, the wheels spin at different speeds at different times during driving so would not be much use to the speedo.
  16. jonco
    jonco Zorg Guru (III)
    Supporter British Zeds The M44 Massive
    Dec 6, 2011
    1,327
    666
    149
    Chester
    Model of Z:
    '98 1.9 Auto
    Agreed - if you have access to INPA - engine module you can see the temp readout varying by ~10 degrees as stat controls even though instrument cluster temp guage remains steady. Maybe stat was faulty on previous Zed hence slow warm-up.
  17. oldcarman
    Feb 11, 2014
    9,986
    3,617
    177
    Model of Z:
    Nothing a couple of tongue depressors and elastic bands can't overcome. It's the slivers that are the problem but I think if I use sandwich wrap first should be a go!! What are you using?
  18. oldcarman
    Feb 11, 2014
    9,986
    3,617
    177
    Model of Z:
    Thanks, I didn't get any owner manuals with the car. I'll see if that works now that you've cleared that up. JIM
  19. zedonist
    zedonist Guest
    It's still intermittent Jim, as I say, but I will sort it out soon.......let you know the solution in another three years......
    • Funny Funny x 1
  20. vintage42
    vintage42 Dedicated Member
    Dec 24, 2013
    227
    66
    39
    More than that. The needle reaches vertical resting point at 155F and stays there until 205F, the highest I have seen my 1.9's temperature go on the ScanGauge sitting in traffic on a hot day.
    http://i49.photobucket.com/albums/f280/vintagefortytwo/BMW Z3 Related/ScanGauge/ScanGaugeOn_zps0ee4d6bf.jpg
    My (one electric) fan turns on shortly after 200F, so I have never seen at what temperature the needle might go past the vertical toward the red.
    The needle stays vertical throughout a wide operating temperature range, even as the ScanGauge shows the actual temperature varying constantly with driving conditions.
    #20 vintage42, Sep 18, 2014
Share This Page
