Ferdinand
Hmm... serviced my 3.0iA 05/2002 km 86.000km 2 weeks ago as follows.
Changed:
Engine oil an oilfilter.
Brake fluid.
Cleaned and lubed brakes.
Added a can of injector cleaner to the fuel.
Cleaned airfilter (K&N)
12V Battery to 74Amp 740 cca AGM-type (original battery was from 2002)
Did a reset of the service indicator (km, time)
I changed the battery because the car had a funny way of starting a couple of weeks ago - it cranked ok but idle was veeeeery slow - It sounded like starting an old carburettor car - so I stepped shortly a quick touch on the accelerator pedal "to make it up" - and that made the idle rise immediately.
I thought that a new battery remove this problem - but got a Whole lot wiser yesterday - problem was apparently still there - because it did the very same thing again.might be because of an old battery ( it was the original from 2002) so I didn't bother to check it - just bought a new one....
Should I suspect the MAF because of the airfilter? - petrolpump? fuel pressure regulator?
Spark plugs has never been changed - could it be them - the car pulls evenly When it runs - gas milage is as normal.
There are no fault codes. What the h... is going on???
Changed:
Brake fluid.
