Sticky slow windows this is a quick how to - nine times out of ten it will be the window runners will need some grease this can be a 10 minute job if you follow this quick guide .
First pop out the mirror adjuster this is done with a small screw driver then pull the electrical block off,now remove the trim around the door pull by pushing it forward .
Behind the mirror adjuster there is a small star head screw remove this .
Now the door card is just held on with plastic clips feel your way around the door card until you find a tight spot and then pull ,do this all round the sides and bottom
Right now for the top tip ! do not remove the door card from the top,but just pull it forward at the bottom there is some foam backing this can be pulled away its only stuck on. The reason for not removing the whole door card is because it can be a real pain to refit at the top with the door pin and rubber seal.
With the door card pulled forward, you can see the window runner, slap a load of copper slip on, then run the window up and down so you can see where the grease needs to,go job done .Reverse the steps to put the door card on.
Si-forks on tapatalk
