Sterling... M Roadster Daily
OldFogey99
I bought "Sterling" in September in the Bay area. - trucked to Nashville.
I have done the following since then:
-treated all rubber/seals with gummy fledge, warm air, repeat
-cleaned the top and sealed it
-bought OEM rear "windscreen" and tonneau cover for top-down days
-replaced the rear window (BMW OEM zipper window)
-oil and filter changes
-coils & spark plugs
-Drain and Fill Diff
-Drain and Fill Transmission
-new fan (the explodie one)
-vacuum hoses and intake boot (was leaky)
- replaced seal in 3rd brake light
-replaced driver's taillight (was crazed/cracked... or something.. bugged me to death) with used matching OEM in perfect conition
-fitted a Apple Carplay receiver - as it is my daily
-New Conti DWS06+ all around
-motor mounts
-transmission mounts
-guibo, Center Bearing Carrier, and associated parts
-stainless clutch line
-stainless brake lines
-ensuing master cylinder seals (hahahahaa)
-installed hardtop fit kit and a Titanium Silver hardtop for winter/summer extremes
-refinished wheels to actual Hyper Silver and replaced "M-blems" on the wheels
Valve cover seals, oil separator/CCV kit, and Idle Air Control Valve hose are in boxes awaiting my time and warm weather. An M50 manifold has been purchased, but I am on the fence about it... because it inevitably involves an (actually cold) air intake, 3.5" MAF, schrick cams... tune.... keep ASC or delete... hahahaa... it gets real bad real fast. I will likely do oil pump nut and timing chain/guides before intake shenanigans.... because I am forever tempted by Aussie ITBs on the S52.
Scratch/chip correction and a full paint correction are on the docket t some point.
Pickup Day Photo:
You think that looks tiny, you should've Frankie's M between 2 American cars outside Denny's on the US192 in Kissimmee a couple of years ago.. It really did look like a bit dropped off.
How tiny it looks next to that Porsche :oops:
yep. With the exception of length, they are, in fact, incredibly close by the numbers! buuuttt... It doesn't look like that.
Wheelbase
Cayman 95.08
Roadster 96.8
Width
Cayman 70.91
Roadster's 68.5
Length
Cayman 172.13
Roadster 158.46
I don't have numbers on the Roadster's track width front & back, so I can't compare that.
Cayman is 221 lbs lighter and has 55 more horsepower... but.... with the exception of the "float" from being hooked up turning one direction to being hooked up turning the other direction, the little roadster does alright. hahahaha...
(related caveat... I'm not sure that I will go with DWS06+ again... it didn't float this bad before these went on... oddly the previous tires were Conti contact sport+... the Discount Tire exclusive "version" of the DWS06+ ??? gah.)
Some time has passed since I've updated.
This week I pulled the intake components and installed...
Race German Intake/Filter housing
Bremi 3.5" HFM [pins 1 & 4... black and brown/orange need to be tied for the ECU to read the ...803 HFM - Bosch or Bremi]
Bimmerworld ASC delete silicone boot ( I made a 10 Ohm 10watt resistor connector - so that I can disconnect and remove the actuator for ASC - but it could always be put back if need be.)
Dinan BBTB
New Throttle Position Sensor (because why not at this point)
M50 intake manifold (m50manifold.com kit w/ Race German IAT threaded for the M50 manifold)
new BMW AOS and hoses, new ICV host to Bimmerworld boot
24lb injectors (Bosch 0280155832)
Remote tune from Randy at Epic Motorsports
Purely to have a objective data point the mods, I timed several 0-60 pulls with Dragy. The best time I could muster was a dissappointing 6.57... buuuut that 1st to second shift takes forever in my car.... forrrever... also on All Season tires.
After the mods, I managed a 5.93. That's still not to factory spec, so I decided to check cylinder compression.
With the engine warm (not hot), numbers were 181-186 - that's within 3%. Without knowing what this compressino guage would read on a known cylinder, I don't know whether it's in the 180s because of the rings in this motor... or whether it's a global variance with this guage and 14mm adapter.
All of that said, after putting a few hundred miles on the tune - rolling plenty of backroads, it is pretty dang good.
We were at an even the other night with loads of super and hyper cars - GT3RSs... Guntherworks, Pagani, plenty of Ferraris, an actual OG Cobra, and again - more 911s than is reasonable in one building.
Driving home - on the backroads with the top down, I don't know if I would enjoy anything else more (on the street). The power and chassis are perfection for sporty street driving. It would get slaughtered on a track with long straights. hahaha
Next up -
1) Ireland rear Subframs and OEM Trailing Arm bushings, new rear sway bar bushings and end links)
2) Front end refresh (control arms, donut, tie rods, sway bar bushings, end links, and mount)
3) mechanical fan delete - lower temp thermostat, lower temp aux fan switch, stewart water pump, aluminum WP pulley, new belts
Having been at least this far I'll say: If it's about horsepower and torque, anyone's money is better spent just buying a S54 roadster. I've become attached to the S52. I like (the idea of) not having to have valve adjustments and bearing replacements on the regular. ... and it IS a blast to drive... making an S52 perform significantly better than stock (or even as good as in my case) is just not an easy or cheap path.
gah... I think that's it. .. busy fall. Hard Top will be back on in a month or so.
Today's Project: Front End!!
MOOG Control arms w/ Turner 80A centered bushing & bracket along with Lemforder Tie Rods.
Front Sway bar end links and bushings will have to wait.
BEFORE/AFTER
Before
: Steering wasn't bad, and there wasn't a lot of slop that I could feel - I saw that the lollipops were looking dry rotted and figured it was time.
After: Wow. I expected more "steering feel" - whatever that is... and a little less "give" on center. I expected more harshness over bumps. I was not ready for how stable the car now feels at speed and in corners. It is absolutely transformative! (Lift off oversteer and the chassis flex in the midst of it is still very real! hahaha... can't unPhysic Physics)
It was a good amount of labor - as reaching the nut that secures the pivot ball joint of the control arm to the subframe... was... not convenient. I ended up using an open ended 22mm wrench and it took forever. If I was in purgatory, that nut would be my boulder.
I would 100% do it again, and I 100% recommend the parts. ECS (USA) had the tie Rod Replacement Kit - had parts I would not have known that I needed (like the very specifically designed lock washer for the inner tie rod).
Today's Project: Front Sway Bar Bushings and End Links
Powerflex Street-Series, new brackets
Garagistic E36 M3 / Z3 M Billet Adjustable End Links (matched to stock length)
**of note for those using these end links. They are thick in the middle and make left-to-right positioning critical - to avoid contacting the cable housing bracket on the strut when the wheel is turned.
If I had it to do over, I would probably use another end link.
Don't worry about trying to hit factory or road test claims on 0 to 60 times. Yiu probably never will. Dont know how bmw do it but some tests only start after the car has moved 1 foot or so and is well on its way. These numbers are produced under ideal conditions of grip and temperature to get the best result. The drivers are experts at these runs which the rest of us probably are not, for an s52 car your numbers look OK to me. Also what altitude are you at anc what temperature was it?
700’ altitude and 70s or 80s F for temp.
again- my 1st to 2nd shift is looooong.
appreciate the insight!
The altitude is not bad. You will be down about 2% or 5hp from stock. Colder weather would help a lot with that. On a 49 degree day you would be back at sea level air density. The temperature has a huge impact on na performance. Now all I need is a -28f day to get my 50hp lost from altitude back. Lol. Not going to happen.
Today! (actually 2 days ago)
Stromung Axle-back exhaust!
Exhaust has bigger tips than stock and is much lighter than stock (stock was 34lbs each side). Sound is low and rumbly - and even at 7,000rpm, never gets harsh or raspy.
It's pretty great at idle - quietish... it does drone when "lugging" around 1700rpm. ... with the top up, it's... a thing.
Other than that, the exhaust is great! - It truly freed up the intake, injectors, and tune and made the whole mod package come alive. The S52 revs MUCH more quickly now throughout the rev range.... The engine also starts instantly at the turn of the key like it used to before the mods.
I'm still chasing codes (227 & 228) for a mixture deviation that pop at startup randomly... once or so a week.
I did check all vacuum lines today - and I pulled the HFM out of the elbow and used a leak tester to pressurize the intake with smoke. - no leaks.
I reset all adaptations and drove some. We'll see if they come back.
A few days - no CEL or codes. That's good on the tune/injector/fuel pump side.
Today I changed Transmission fluid. I had been running BG Syncro Shift II... there is a segment of the track community (seemingly mustang folks??) who swore that the syncro shift was magic, and, in a way, it was...
The shifts that were smooth were butter. The 1st ->2nd shift got worse... and was a burr in my saddle.
As expected - micro brass filings from the syncros were in the trans fluid - which otherwise looked amazing. At some point, I would LOVE to have it rebuilt with new syncros.
I put Redline MT-LV in. It was instantly better from 1st -> 2nd. My best guess is that the BG fluid - though it IS GL4, is just a little too slick for the syncros in the ZF320.
Right now it's getting detailed ... all dolled up for a Dinan/APR Cars and Coffee event tomorrow morning. For some crazy reason, they are going to let me park in with all of the cars people WANT to see. hahahahahaa
The last 2 weeks-
An exhaust smell had developed in the cabin - and with Hard-top weather here, it was not sustainable. Before doing cooling system work, I did everything I could to rule out a head gasket leak or cracked head - as I also had exhaust gaskets to replace, and I didn't want to pull everything (including the radiator and exhaust manifold) only to find out afterward that I needed to pull it all again to do head work.
Exhaust gas test at expansion tank: Negative (good)
Leakdown test: Between 1-2% all cylinders (really)
Borescoped cylinders - cylinder walls, valves, and pistons looked good.
Oil and coolant both looked good.
Replaced:
Cooling-
Radiator (S54)
Expansion Tank, Cap
Upper hose
Lower Hose
Expansion Tank Hose
Overflow Bottle Hose (bottom)
Water Pump (Stewart) & WP Pulley (aluminum)
Thermostat (88c)
Coolant
Deflection Pulley
AC Pulley tensioner and Pulley (broke the original tensioner trying to get the pulley off).
Belts
Exhaust-
Cats - High Flow cats welded in at shop (suspected failed/clogged cats due to performance not quiet what it should be, back-pressure drone, excessive exhaust "filth", rotten egg smell, and... blown exhaust gasket somewhere in the chain). Car was instantly an ANIMAL in the power band after the high flow cats were installed. The in-cabin drone was also reduced significantly.
Exhaust manifold gaskets and mid-pipe gaskets - I ordered a kit with gaskets, studs, and nuts, and I did this at a local community DIY shop - where you can rent a lift. I never, ever want to do it again. hahaha, but the exhaust shop quoted $1650 (US) for the job. I get it, 26 fasteners and 5 gaskets at the head (including SAP). Access is maddeningly "not good".
*As it turns out, a shop that replaced the Guibo, Center Bearing Carrier, and the Transmission mounts 1 year ago did not use new gaskets on the mid pipe... and/or they did not torque/tighten one of the mid-pipes correctly. This led to a MASSIVE blowout at that mid-pipe gasket... which was the horrible exhaust smell in the cabin - as the exhaust was rising straight up from the joint at the back of the engine bay and into the HVAC intake on the firewall.
so far so good.
Tools that helped immensely... (pics are examples - not my actual tools YMMV)
Carbide Gasket Scraper!!!! This thing has saved SO much time over the years
Offset Socket Extension: It wasn't perfect, but I could not imagine doing the manifold gaskets with the engine in the car without one.
