There is a story to this but I am in urgent need of the above please if anyone has one available @Synclare ,@spurs fan in a coupe maybe.
Steve
Steve
I sure hope this doesn't happen to mine Steve.Well my new wheel arrived as you all know on a Tuesday but due to working late and crap weather I didn't get round to fitting it until Thursday after work.
Got the slip ring swapped over onto the new wheel no problem,but as I slipped the new one on to the splines not realising you have to line up the slip ring which has a slot in it to line up with a little white peg which I think is the self cancel thing for the indicators as it turned out. Big black clouds coming in fast and it starts to rain so in my impatient haste to finish the job and get the outdoor cover back on the car I got it all bolted back together,connected the battery up again,turned on the ignition and no warning lights so all good......at that point .
Saturday morning .......take off the outdoor cover,get in,start the car,all fine
As I'm about to pull out the drive to go to @t-tony's,put some left lock on......it won't turn much,as I'm halfway onto the road with cars coming I force the wheel to turn......felt something snap,air bag light comes on .
Carry on to Tony's to fit the DRL's as arranged.
Tonight after work tried the air bag reset gadget,light won't stay off .
So disconnected the battery,took the steering wheel off and found this
The tape with the copper strips inside had ripped out of the connector block,can't fix this so need a replacement slip ring.
See @Grumpy it's not just you mate..
Doing the Welsh cruise on Sunday and then me and Sara are going to Hugh and Sarah's the next day for a midweek break,so I would like to fix it before then if I can.
Edit : Obviously I didn't line up the slip ring properly on refitting.
Steve
It won't Steve it's just my own ignorance and impatience mate.I sure hope this doesn't happen to mine Steve.
Mate don't beat your self up at least you had ago.It won't Steve it's just my own ignorance and impatience mate.
If your new one is fitted and you've drove the car it would have happened if it was fitted wrong like mine .
Steve
Very true mate,it could have been worse.......at least the air bag didn't go offYou live and learn hey Steve unfortunate but fixable hopefully in time for your break
There is that ! Not something you would want on any level.Very true mate,it could have been worse.......at least the air bag didn't go off
Steve
Let me know if you get sorted mateThanks mate,looked on eBay and didn't see that.
@Synclare may have something,been in touch a minute ago by text......fingers crossed
Steve
Will do Steve,thanks for your very helpful offerLet me know if you get sorted mate
