Sports heated seat repair
Brian4
Near Grantham
Z3 3.0i Auto
Thanks to Gookah
As was the case with his M Sport seats our Drivers seat wouldn't heat up so followed his excellent instructions and took the seat apart. Found a broken wire in exactly the same place so wondering if it is a fault with them. Anyway all fixed and working again now.
The previous owner must have go a very warm bum when it went as the wire had melted the foam backing to the leather.
Brian
Brian4
Near Grantham
Z3 3.0i Auto
I even used the tape trick for the seat bolster but not silver.
Brian
Brian4
Near Grantham
Z3 3.0i Auto
No mine is the electric hood
Brian
Brian H
Killin
E36/7 3.0i - E85 Z4///M
Problem with the electric heated seats it that we at times kneel on the seats, my theory is that this causes the break in the wires, I have one failed on my passanger seat, it has shrivelled the leather up in that area.
Didnt know we had a guide on this, It's a job I keep putting off on Sams zed :D
Fancy coming doing and doing us a tutorial @gookah =))
2.2 Sport Individual
Sean d
Lincolnshire
I also fitted the same as @Mint , I did the back and the base, they are excellent
Dino D
Kent
2.8 Manual
I would replace it with the carbon heated pads (I’ve done it on my sparcos and in our family bus too!).
Much more even and quicker heating I find as it has plenty of elements to evenly spread and won’t break -can be cut through to fit hog rings etc. With cloth seats it actually gets a bit too hot on setting 2 (but is right for sub zero to own down drives!)
Bozzy
Long Eaton.
I use an old cushion on the seat if I have to kneel on it, so far it seems to have protected the heater elements.
