I'm having a bit of an issue with the above - essentially my battery went flat a couple of weeks ago - went to start, nothing at all. So, charged the battery up overnight and it starts, albeit with a bit of effort and on the second turn of the key.
Prior to it going flat it started on the button with no issues, so i initially put it down to a combination of the cold weather and having stood for a while (only 6 weeks or so, but i had been mucking about changing the seat bushes and suchlike, so I'm not surprised the battery was flat).
I took it for a spin yesterday to put some fuel in, it struggled with coughing and almost turning over the first time, then second time it started. Its a bit lumpy on idle when cold, but once warmed up its seems to be fine (runs well enough without issues).
Earlier today I've taken it out on a run of mixed roads over around 27 miles, and just took it out for a spin to see if started any better - still the same.
Any ideas? I've not changed anything since the battery died (other than the aerial base grommet and removed the headlights to fit halo's (which aren't yet wired in)) so I'm at a bit of a loss.
It's a '98 2.8 Auto if that helps....
