Billy had a look on the net after reading your post came across a couple of different sites with torque settings for split rims i found one that listed bbs oz and compomotive together they vary a couple of pounds/feet depending on make but all were between 22- 26 lbs/ft with a spot of locking solution hope this maybe helps a bit
Also just thought I'd add i would tighten progressively in a spiral pattern put 1 in then do the one opposite then the one opposite that and so on till all in. then nip up. then torque in the same style of tightening.
