I upgraded mine some time ago with Vibe 140s, you can just remove the speaker and connect the new one to the AmpView attachment 74067 View attachment 74068 View attachment 74069 View attachment 74070 so got new mb quartz speakers and an alpine head unit I want to fit but thought I’d check passenger speaker first. So just my luck it has an amp on it. What’s the best way and easiest to get over this , should I just run new front speaker cables back to the head unit. The amp only seems to power the footwell speakers as door tweeters and rear speakers still work with it unplugged.
Is this ok with changing the head unit too ?I upgraded mine some time ago with Vibe 140s, you can just remove the speaker and connect the new one to the Amp
Yep did mine at the same time, you need to leave the amp as its for the door tweeters, mine still work ok and the system sounds greatIs this ok with changing the head unit too ?
So changed my head unit today for an alpine unit , not new but more period to the car which is what I’m after. Armed with sean d’s knowledge I changed the unit over and left the original amp in place and still on stock speakers. The sound quality is so much better the standard business head unit must be seriously rubbish. I have new speakers to fit at a later date but very impressed in the difference by simply swapping head units.Yep did mine at the same time, you need to leave the amp as its for the door tweeters, mine still work ok and the system sounds great
Are those a straight one for one swap mate? Footwell speakers, door tweeters and the speakers behind the seats.I upgraded mine some time ago with Vibe 140s, you can just remove the speaker and connect the new one to the Amp
Yes mate, I didn't swap the tweeters just all 4 speakers, the front are 5.5 inch and the rear are 4 inch, I used 140 watt in the front and I think the rears are 90s, I bought a vibe set,Are those a straight one for one swap mate? Footwell speakers, door tweeters and the speakers behind the seats.
Nice unit!View attachment 74178 View attachment 74179
