I fitted a set of plugs earlier with my tried and trusted method. Thought I would share it with you. My spark plug socket is missing its internal magnet so I use a length of rubber hose to insert the new plugs down into the recessed holes. You will never cross thread a plug using the method. Easy and a cheap tool too. To keep the hose straightened I store a piece of steel brake pipe inside it.
