... Would advise you go for Iridium upgrade plugs....
I asked about those plugs, and NGK does not recommend them in the M44 engine. Their OE copper plug for the M44 is their BKR6EK (stock #2288). The exchange below says if you want a rare metal plug for the M44, use their platinum PFR6Q #6458
Sent: Thursday, November 29, 2012 3:57 PM
To: Info
Subject: Re: NGK Form Mail
Andrew,
I appreciate the info, and would like to explore the question of using the NGK BKR6EIX Iridium in the 1997 BMW Z3 1.9L.
I know the NGK BKR6EIX Iridium is not a two-electrode plug like the NGK BKR6EK, which is more similar to the OEM Bosch F7LDC that had four electrodes.
But many people have used the NGK BKR6EIX Iridium in the BMW M44 4-cylinder 1.9L motor, claiming advantages like better spark, better idle, and longer life. So if that plug, though differentfrom the OEM design, is apparently compatible, then why not list it as compatible?
Are there any problems, or could there be any advantages, to using the NGK BKR6EIX Iridium in the BMW 1.9L?
Info@ngksparkplugs.com>
Subject: RE: NGK Form Mail
Date: November 29, 2012 at 5:02:39 PM EST
To: Allan...
Sure,
The BKR6EK has a 6.0mm firing position with two ground electrodes and a 1K ohm internal resistor. The BKR6EIX has a 3.5mm firing position, with a single ground electrode and a 5K ohmresistor. The firing position might create some engine response lag, but the real concern in the 1K ohm resistor. The ignition in the Z3 is setup for a 1K Ohm resistor and the 5K resistor maycause random misfires. Here is a picture to explain firing position visually. I would realistically not recommend the BKR6EIX for the Z3. Instead I would recommend a PFR6Q #6458. This is a finewire Platinum center electrode, which will perform just as well and the IX and it has the correct 1k Ohm resistor internally.
Best Regards,
Andrew Hauenstein
Technical Training Specialist
NGK Spark Plugs USA Inc
