southernboys z3 seat belt guide repair kit
fitz
Help could anyone tell me if this is available and how I obtain a set or get in touch with the seller.
Hi fitz, should be available-I only got mine a short while ago. Message southernboy on here & he will get back to you regarding payment etc.
Pleased with mine, they look great!
these look really good ,how much are they? i fixed mine with some black Heat Shrink , and used the gas solder gun to shrink it on
View attachment 11430 Hi fitz, should be available-I only got mine a short while ago. Message southernboy on here & he will get back to you regarding payment etc.
Thanks have ordered parts,can you tell me what size screw fixings you used bearing in mind not wanting to obstruct belts.Also have gained quite a lot of info reading the comments.Only just purchased z3 so have not yet used much, trying to clear garage to house the motor,have it covered with a cover advertised as being for the z3 is this a good thing. Again thanks hope I can call on you if any probs. Fitz.
Hi fitz, the screw fixings come with the parts so you won't have to source them.
Regards.
@fitz, you have joined possibly the forum with the most knowledgable Zed owners with enough tech help to assist you with most any problem no matter how small or big. All you need do is ask and surely someone will get back to you almost immediately in most cases. So don't be shy about throwing something out on here. These guys and gals are your lifeline as long as you choose to use it, JIM
