Sony MEX-N4100BT
I think a few of me have heard me moan about my current Sony MEX BT3800U head unit and the bright white LED on the front panel. This is how it's been for the last couple of months with insulating tape covering the LED.
and without showing the white LED strip. The dim controls in the settings dim everything else except these two strips.
Being bored on a Sunday morning I finally got around to browsing head units and ended up in Halfords to buy a Pioneer unit, and ended up walking out with a Sony MEX-N4100BT instead for £99.99 (cheaper if bought from Amazon).
http://www.sony.co.uk/electronics/in-car-receivers-players/mex-n4100bt for more details.
There are a couple of reasons for my change of mind. Firstly that I have a Sony unit already and it's pretty darn good matched with the Harmon Kardon audio setup (despite the white LED). Secondly I lost the removal keys for removing the head unit, and the new unit would come with some.
As you can see from the spec it's pretty much got everything covered, but my main requirement was a display which had better control over the illumination and this has this in buckets. Choice of either blue or red display, fully dim-able display which controls the main LEDs as well as the display. Also needed Bluetooth so I can stream from Spotify through my Samsung Galaxy 5S (this does have a CD unit as well unlike some of the other units out there). USB port for charging my phone on the go! 4 x 55 watt outputs is up slightly on the older Sony unit too.
In the box...
I won't go through the process for switching the head units over, there is a guide in the article database I wrote when I bought the MEX BT3800U unit if you are interested.
Not the most attractive looking item, but it'll do as it doesn't burn my retinas. Sound quality has improved and the bass is pretty insane through the HK sub - didn't expect it to be that much better than the old unit.
Very nice at that price too.
Antm72
South Yorkshire
Maay be a dumb question but are you using this through the hk system ? I thought you could not use an amped head unit with the H.K system ?
Mine is the later version of the HK system all I've done is change the head unit.
Not sure about the earlier version, but seem to have a vague recollection about the earlier ones being more tricky to mess with.
Z
zedonist
Guest
IT all depends on the condition of the oem amps, if they have had relative low use,most get away with using them, as per Gaz setup, older and more used units suffer from age and tend to clip when over powered, the fairly new systems will keel over at some point too, so is just a waiting game as you should not put an amped signal through an amplifier...
littlefeller
evesham
now you tell me this, after i gone and fitted a new head unit this weekend with NO streaming:mad: ah well guess i will have to make do for now.
Davyhoogy
Sunderland
'98 2.8 z3
I've actually been after this unit it's stood out to me so been browsing ebay. Is it a straight plug swap from a 98 oem head unit do you know? Or will I need an adapter?
Cheers
Davyhoogy
Sunderland
'98 2.8 z3
Been ebaying, they're going for 70ish so might just get a new one. Halfords have the mex n5100bt for cheaper than the 4100? £90
