After renewing suspension bushes the next thing to look at will have to be the Anti-roll bars, the bars themselves and the mounting bushes. Preventing body roll comes before lowering.
It's just because they are screenshots. I'll upload the proper picturesThanks for your reply. It looks great. Unfortunately only some of your photos show. The rest are black squares.
I wasn't even aware that solid M rubber bushes were a thing for the e30 back end. I knew solid M rubber bushes were available for the lollipops at the e36-based front, which I plan to do at some point. Mine had poly'd lollipops when I bought it. I swapped these back to standard OEM rubber when I replaced the wishbones and noticed turn-in was slightly softer. I then replaced the front shocks, springs etc with OEM items when they were knackered.I think I will go for poly bushes in the front and M solid rubber ones in the back. As far as I know the M bushes will fit at the back.
you have to turn the tyre on the rim though first, so the worn edge is on the outsideThe negative camber can affect tyre wear but if you use directional tyres you can swap them from side to side to even out the wear.
wasn't what you wrote though....That's what I meant, turn the tyre on the rim.
