Solution to Fuel Gauge/Sender problem
bonbon
Israel
19L Auto
Has anyone considered changing the fuel cap to a vented one in order to avoid creating a vacuum in the fuel tank which collapses the tank wall and can cause the notorious damage the fuel sender?
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
3.0L, 2.8L, 2.0L Z3 Roadsters
Isn't there an evac valve that is used to detect leaks in the fuel system that pops up a warning light? Or am I thinking of E46's?
bonbon
Israel
19L Auto
I hope not. I’m banking on this being a solution to overcoming Vac in the tank.
NZ00Z3
New Zealand Zeds
Timaru, New Zealand
Easy way to test it, don't fit the fuel cap properly, leave it loose. See if any lights pop up.
I know a loose cap will pop a light on the E46's, just can't remember about the Z3's.
137699
Hampshire
M Coupe 3.2 S50
Surely a vented fuel cap is just going to lead to a strong smell of fuel outside of the car & a potential fire risk?
No way that would pass an MOT here in the UK.
DomiMik
German Zeds
🇭🇷 》Croatian living in Germany《 🇩🇪
Counter question: why not simply change the charcoal filter which is the main cause for the problem? When I started to notice the first signs of vacuum in the fuel tank, I bought a new filter and replaced the old one, shouldn't take more than 20 minutes. The old one lasted 20 years, so I think that's a simple and not too expensive solution
(~ £ 110).
After all this will eliminate the problem, a vented fuel cap only eliminates the symptoms.
vetinari
I had an engine warning light pop up last month on my 2001 3.0i . The problem turned out to be a loose fuel cap . I don't think a vented fuel cap is the way to go .
Vetinari
bonbon
Israel
19L Auto
I don't think a loose cap, and a cap with a one-way-valve is the same.
1. It's surprising that your light was triggered with a loose cap. I now disconnected the charcoal filter and no light was triggered....
2. I thought the problem was a faulty release valve and not a blocked filter. Either way - it's an embarrassment to BMW how many millions of dollars they made on replacing sender units.
The Z3 has a anti vac valve already fitted, if you have a vacuum issue I would say its failed.
