Soft top rear window cleaner
not sure if anyone else has tried wd40 on the rear window but it works a treat
Is it just as a general cleaner, or does it help with the hazing/scratches.
I normally use Autoglym SRP to clean mine as it reduces the small scratches in the plastic.
B
badman gee
Guest
You can get better stuff than srp that doesn't contain fillers.
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
BMG, I'm putting a brand new window in so please expand on your post. I'd like the window to outlive me, if possible. JIM
bruce&kim
It worked well for me Gaz mine was scratch free but had a line from folding etc ..it removed that as well as the fogging
B
badman gee
Guest
Greygate plastic polish is very good, it removes any light scratches.
Meguires plastRX is good as well.
The graygate seems to be slightly more abrasive than the meguires.
Both are very good and are designed for plastics.
Ensure you use a fine microfibre cloth when working on the window.
And of course make sure the cloth is new or very clean.
