Last Sunday I thought I would go out as it was a nice day so got ready, started car, got roof ready and pressed lower button - nothing. tried again checked brake was on checked roof switch was operated still nothing.
Checked all fuses as you do so I then got the wiring diagram out and started checking circuits. I had lowered the roof manually by this time to see if it would come back up but nothing, but whilst I was sat in the car with the boot open I looked back and noticed I had no brake lights and sure enough the switch had an intermittent fault on it. I had passed the MOT 2 weeks before.
Anyway I have replaced the switch from Euro car parts and all is ok again so if your roof won't lower check first you have brake lights before you delve any deeper and save wasting a day.
There was also a gearbox fault showing and the brake switch is wired through the 2 computers along with the gearbox so I left the battery disconnected, whilst waiting for the switch, and all faults have been reset so will be out next sunnyish day.
Brian
Brian
