Wanted Smoked side (bumper) lights supplier
Dino D
Kent
2.8 Manual
Managed to chip one of mine when not clipping it back properly after testing out LED bulbs so need a new set.
I’m quite sure bought my last set from Germany last year for something like £30.
Can’t seem to find the site again.
Found a UK EBay seller but it’s £45.00!
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/331541363834
Does anyone know the German site or know an alternative source for these?
Jjim
Mansfield
1.9 Roadster
I’d be up for a set if you want to do a group buy to reduce shipping costs.
Lazzzydog
Put me down for a pair as well if you go ahead. That brings the postage right down.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
They do smoked side repeaters also, I think there was talk of a group buy last year but nothing happened. Seems a few now want them so will be a good way to share the postage. Delivery was fast as well when I had mine.
Replaced mine about a year ago from the German ebay seller they were a reasonable price then, seems they are a popular replacement hence the hike in price.
Sean d
Lincolnshire
Something to do with the Euro as well
I'm planning on deleting mine and using Halo's as my side lights, would this be OK for MOT @t-tony @Stevo7682
Yes Sean, you need two lights facing the front, white light, equal distance in board and equal height. They just need to come on with the rear "position" lights and Reg. plate lights with on switch. I'll see if I can find the manual detail mate.
The front and rear position lamps must light up at the same time with the registration plate lamps and end-outline marker lamps.
It must be possible to switch on the position lamps from the driver's seat with a single operation of the switch. The position lamps must light up at the same time as the registration plate lamps and any end-outline marker lamps where they are fitted.
The precise position of lamps isn’t part of the inspection. You should check visually that they are at about the same height and distance from each side of the vehicle.
A ‘light source’ means any bulb, LED or other means of emitting light.
You must assess repairs to lamps for security, colour, light output and durability.
Position lamps
Rear position lamps must emit a steady red light.
For front position lamps, the following colour of light is acceptable:
  • white light
  • predominantly white light with a blue tinge
  • yellow light – if combined in a yellow headlamp
  • Hope this helps Sean.
  • Tony.
Since Tony gave you the long version I will do the short one .:thumbsup:
Yes that's fine as long as you comply to regulations that Tony has posted :):)
Ianmc
New Forest
Z3 (M44)
My Z3 doesn't have these, being an early model. Side lights are in the "proper" place, within the headlights.:thumbsup:
5harp3y
Here you go @Dino D. This is the site I had mine from, fast delivery but delivery is 14.50 euros on top but they still work out cheaper. Worth getting a few things together as the delivery charge stays the same I think.
Showing as not available
