Small parts to check for and pull from a Z3 salvage vehicle?
96Midlifecrisis
I am pulling some parts off a vehicle already. Are there any small parts that would be worth checking for and grabbing? The interior is pretty much gone so it would be mostly mechanical items. I thought of the items below. Any others?
Wheel spacers
Wheel spacers
calipers if upgraded
pedals if upgraded
guage cluster
mirror
master brake cylinder
wind deflector
throttle position switch
Thermo-Time Switch
DISA valve
O2 sensor
trunk tool kit items
Trunk light plastic cover
96Midlifecrisis
Updated list:
1/4 panel - I already took
rear light lens and housing - I already took
trunk plastic cover over latch - I already took
Trunk latch - I already took
DISA valve - I already took
Rocker panel - Damaged
Trunk lid - Damaged
wind deflector parts - Grab
convertible top window (if in good condition) - Grab
convertible top part if in good shape - Grab
Driver side trunk hinge - Grab
Trunk light plastic cover - Grab
MAF (especially if it is Genuine BMW or Siemens) - Grab
Head light switch and knob (if available) - Grab
Heater control valve - Grab
Rear speaker grills if in good shape - Grab
ABS DSC control module - Grab
yaw rate sensor - Grab
Steering wheel clockspring - Grab
Screw caps and “srs” covers for door card screws - Grab
Steering rack - Don’t need
roof assembly - Don’t need
master brake cylinder - Don’t need
throttle position switch - Don’t need
Thermo-Time Switch - Don’t need
O2 sensor - Don’t need
drivers side door sheet metal in good shape - Don’t need
Wheel spacers - n/a
calipers if upgraded - n/a
pedals if upgraded - n/a
gauge cluster - n/a
side mirrors - n/a
trunk tool kit items - n/a
Headlights - n/a
TriumphZ3
Rear wishbones?? (I need a pair!)
96Midlifecrisis
Updated.
Trunk items:
Trunk latch -
Trunk actuator -
Trunk lock -
trunk carpet if it doesn’t have the cd player -
convertible top pump -
trunk hinges -
antenna base -
battery clamp -
Engine compartment items:
DISA valve -
Steering rack -
idle control valve -
yaw rate sensor -
Headlights -
blower -
Fuel Pump Relay - 8-Prong - Black -
other Relays -
O2 sensor -
Interior items:
air controls -
steering wheel clock spring -
gauge cluster -
Roll hoops -
air bag control module behind console -
seat occupancy sensors -
wind deflector and mounting parts -
Wheels:
Rims if desirable -
Wheel spacers -
calipers and rotors if upgraded -
Duncodin
Pontrhydyrun
Z3 M44
Updated.
Trunk items:
Trunk latch -
Trunk actuator -
Trunk lock -
trunk hinges -
antenna base -
battery clamp -
DISA valve -
Steering rack -
yaw rate sensor -
Headlights -
blower -
other Relays -
O2 sensor -
Interior items:
air controls -
gauge cluster -
Roll hoops -
Wheels:
Rims if desirable -
Wheel spacers -
I didn't see interior door pull handles in your list. They go on the bay for a fair wad of cash.
Shoejohn
Wow. Absolute gold mine. Congrats. I recently checked my local places and they didn’t have any Z3’s
