Single to twin lambda swap.
Juvvajuvva
Hi,
recently I have swapped my single lambda set up to a dual set up but am still using twin 2.8 o2 sensors in S50 manifolds.
Does any one know if the 2,8 lambdas , that are indeed shorter than the z3m ones can actually correctly make the flow calls to the ecu , and does anyone know, a/ the specs of both and which software would be best to interrogate with?
ICOM or INPA/ISTA etc.
