Hi mario the diameter of the hose that connects to the air flow meter is 90mm I believe on a 3.0 it is larger so would have to get the right diameter hose to make it fit cheers tony.
I would not mind a hose to reduce this would be to fit a smaller diameter filter into a bigger diameter MAF - if the bore of this filter is smaller than my MAF diameter won't I be restricting airflow to begin with?
