Deox gel is wonderful stuffSuccess... Took a bit longer than I expected, but the first sill is off. I could grow potatoes in the soil that came out of the dirt trap at the front end. Rust doesnt look too bad. I shall attack it with Bilt Hamber De Ox and zinc primer over the coming days. No holes or really thin bits. I think the outer sill may be past the point of rescuing (see pic 3 below)- and there is a rust patch on the outside, so it would need rubbing down and re-spraying anyway.
Only other query is the plastic bit hanging down behind the rear jack point (see pic 4). What is it, and should I be doing something with it?!View attachment 126621 View attachment 126623 View attachment 126625 View attachment 126627 View attachment 126629
How much was a respray? Most of my panels need some form of paint work and i wonder if a respray would be more cost effective.The Imola inners weren't too bad, cleaned up, treated sprayed with galvanised paint then a filler primer and they were eventually sprayed in Imola 2 top coat when the car got its respray. Old outer sills were binned and new ones fitted.
£2500 with me stripping the shiny bits off, lights trim etcHow much was a respray? Most of my panels need some form of paint work and i wonder if a respray would be more cost effective.
