Sill removal and rust prevention
z3cade
Peterborough
Jack up the car and place on axle stands
Remove wheels
remove rear arch liner
Remove kick pannel trim and door rubber
remove kick pannel plastic plug
Remove kick pannel by lifting up
You may brake some plastic clips so remove broken clips from holes
Remove front arch liner
Remove screw from front arch, top front of sill (use 10mm ratchet)
Remove three screws for the small side pannel, detatch side repeater and remove
Get a friend to help, but a good friend not a nutter... s:rolleyes
Remove screws from under the sill
Remove screw from rear arch
Remove small plastic trim from inside door and remove bolts that hold rear arch to allow better access for the screw behind it
Remove finnal bolts from top of the sill that were under the kick pannel and remove sill
Clean up box section and check for rust
Treat areas with rust with your prefered products
I used zinc 182 primer, clear waxoyl spray for inside box sections and original waxoyl underseal
Treated rear box section
Treated front box section
Sand down any rust found on the sill and treat with your desired products
Now just reverse the removal process and replace the sill, Job done :-bd
brill!!! :D great and very clear pics,do fancy doing mine,great hourly rate.lol
Great post Liam s:D
great wright up s;)
Great tutorial Liam, want to do this myself sometime so many thanks. :-bd
Looks like he sat down on a spanner or something...... :ymapplause:
Great work Liam,
I think anyone could follow that! I have put a copy in the Z3 knowledge section, and will add it to the wiki next year ;)
Gary
Thanks guys yes feel free to use it. Hope it helps out anyone wishing to do it.
I'd recomed doing it to help prevent rust forming in the future as these areas seem prone to muck collecting and staying damp..
Damp, what does that mean.. Happy new Year mate, great write up. :ymparty: :ymparty:
might also be worth putting some waxoyl inside the door aswell. Had my door card off to grease the runners and the bottom was filled with a horrible smelling brown mixture, other than that great write up.
oooh it felt good s:mrgreen
Excellent guide - I have so far only removed one side of my 98 1.9 Zed. I was quite pleased/relieved that the actual sill was in good condition except for expected moderate surface corrosion in the wheel arch lower voids. These are easily repairable but of more concern was corrosion in the lower front corner of the wing panel which was only removed for access. Refer to pics -there was a `sealant' run along the length of the bottom edge and it lost some contact in the front corner creating the obvious mosture trap. The contour line of the rust is where the sealant was. The `sealant' resembled rock hard putty and was very difficult to dig out without damaging the metal and therefore I have only cut it back to clean metal. Don't know if this is original or a previous owner's diy attempt. Has anybody else got experience of this or a suggested repair/ replacement sealant. I am considering installing an additional plug in arch liner at this point to make Waxoyl injection easier in the future.
My apologies for replying to this very old thread. Excellent guide for anyone hoping to remove the sills. Some years ago I removed a set of sills from a scrapped Z3 and as raised by jonco, I found the sills have sealant around the edges to prevent ingress of dirt and water to the inner sill area. This sealant definitely looks original and I think it is essential that a seam sealer or a suitable silicone sealant is used when refitting the sills.
I am currently refurbishing the spare sills and like to know of a suitable replacement sealant to use when I replace the sills.
There are many makes of panel sealant just google it or go onto amazon. Guessing it will be the same in Oz
Thank you Nodzed for the response. The exact auto body sealer is not available in Oz but there are many polyurethane seam sealers such as Sikaflex 227 and multi purpose non sag sealer Sikaflex 221 are available here. There is also a 3M product recommended for automotive application. I am not certain if these products are suitable.
